Tom/Barb wrote:
ScottG wrote:
Tom/Barb wrote:
ScottG wrote:
That's not the case. It trips all the GFCI's at the facility but is ok on a standard 30A (no GFCI).
We do not know all the GFIs at the storage facility are good. they are probably all on the same circuit. and wired wrong.
a cheap tester will eliminate the doubt.
to determine if it is the trailer, simply read continuity between the two hot leads and the common ground on the trailer plug, it should show and open.
If it doesn't show an open circuit, it would pop the 30 amp breaker at home or smoke something.
If a GFCI is wired wrong in any way, it will not work (trip) under any circumstances.
but it can be wired wrong and work
we don't know if this is a new build. and if any trailer has worked as wired.
We also don't know if this is a new trailer.
I'm sorry Tom but you are mistaken. A miswired GFCI will not trip.
