ScottG wrote:
ktmrfs wrote:
Tom/Barb wrote:
DBECHEN wrote:
Hi all, I have been having a problem with plugging into the shore power at our storage facility. They have all circuits run through GFCI outlets on the pole. When we plug in and we are not running anything the GFCI trips on the pole. We talked to our storage facility manager and they had an electrician come out and he said the issue was our RV having an open ground. We have a Progressive Industries surge protector that was installed by the first owner. When we plug into the 30 amp plug at our house and in campgrounds there is no problem. Any ideas what may be causing this? Thanks in advance.
You do not tell us what Amperage you are plugged into at the storage facility.
GFI protection is very rare for 30 AMP circuits So, I'd assume you are reduced to a lower amperage circuit like 15 AMP or maybe a 25 AMP circuit.
And your Surge protector may be having a problem with it.
120V 30A GFI breakers are not very rare at all. maybe not many installed, but even lowes and home depot have them on the shelf. I had not trouble at all getting one when I installed a 120V 30A circuit for trailer power.
Oddly, GFCI is not required by NEC for a "Trailer" 30A supply or even a RV 50A outlet.
At the storage facility it is plugged into a 120V 25AMP circuit. At home into a 30A non-GF I outlet.
