wnjj wrote:
enblethen wrote:
Turning off breakers or on will not show a GFCI issue as breakers do not open ground or neutral leads. You must physically open that portion of the system. Problem could be any where in the 120 volt AC system.
Refer, water heater equipped with 120 volt AC element or converter would be places to start.
Generally true but there could be a device that only leaks current to ground when powered up and flipping breakers is simple to try as a first shot.
Your point is precisely why some have suggested unplugging the fridge to eliminate the heating element.
Which is why I said
start by turning breakers off. If that doesn't come with anything, then time to dig deeper...
