A motor that trips a correctly working GFCI has a real ground fault. I'm guessing the refrigerator exception is there because some fridges do have ground faults and there was tremendous public and political pressure for the exception. Personally, I've had 2 refrigerators and a freezer on GFCI circuits continuously for 9 years with zero trips. I run the RV including the heat pump, air compressors, and an irrigation pump with no GFCI trips. The only trips I have had are from making some mistake when making a temporary connection or with using test equipment (like forgetting that one side of the scope probe is earth grounded).
