smkettner wrote:
Jbird wrote:
Thanks folks. After reading the link re grounding generators I see I have had the open ground issue with a generator for 9 years thru two fivers and have just now discovered it because of other electrical problems. So it's either not to worry or Im living on borrowed time when using my generator. The link seems to encourage either view. Thanks again
What are the other issues? We can help with those but the rest is normal.
I appear to have lost one hot side of 50 amp in from one of two sources to transfer switch. Either bad transfer switch or bad source. Haven't had time to check it out yet.
