enblethen
May 02, 2013Nomad
Proper ground is necessary on products requiring external connection. Siz eof the ground is based on the size of the unit.
300 watts would not require much over a #14 ground. Memeory says the ground is 12.5 % of the max rating of the device.
I would run a separate ground and not tap onto any existing grounds. Those grounds would (should) have been calculated on the loads originally connected.
I just went to website and looked at manual for the unit. The designer sure wants oversized wiring for DC power and ground. They advise #4 for ground, min #6 for power and fused at 100 amps. This seems exremely high for the 3 amp 120 volt output.
Manual
Manual
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
