enblethen
May 02, 2013Nomad
Morningstar says the ground to the inverter must be larger then the DC power wiring. Why? I donot know!
The AC line indicates putting the neutral to earth ground. Strange! Sounds like they are using the heat sink as neutral. Make sure you frame ground is good as it is doing dual functions.
Ground 30 amp receptacle to frame with min #12.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
