westend
May 03, 2013Explorer
I think a separate case ground is used on some inverters so that if the 12v negative is not present and the inverter fails, creating a short to the case, a ground is present to protect the user and connected parts. I have my inverter mounted on an aluminum plate so if the inverter case was energized, the mounting plate could also serve as a ground plane, something I wish to avoid. For the Xantrex SW1000, I used a separate AWG 8 to frame ground point.
As BFL has said, the tester may show no bond between neutral and ground for 120v receptacles and be correct.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
