When I check the pedestal my indicator shows an open ground. This is on the 50amp side. What does that mean and should I be concerned? What risk am I taking? Thanks, John
The Ground is a safety device, if it is open then you are at danger.. There are ways you can deal with it (I do on occasion) but as others have said, Report to park management, get THEM to fix it (NOTE check the outlet itself if you can)
Having RV issues? Connect with others who have been in your shoes.24,200 PostsLatest Activity: Feb 19, 2025
