wolfe10
Dec 02, 2014Explorer
Most likely suspect (assuming not a CG issue) is the ends of the shore power cord. They are exposed to more "action" than other parts of the electrical system.
If you have an ATS (Automatic Transfer Switch) be sure to check the connections in there as well.
Other place (least likely) is the connection at the 120 VAC breaker box in your trailer.
