enblethen
Dec 02, 2014Nomad
Transfer switch? Do you have a genset installed in the trailer?
You should not be reading any voltage if you are measuring between neutral and the phase conductor if the neutral is truly open.
What type of measuring device are you using to read and record voltage?
Common point could be your 30 amp cord body.
