tammyinwv
Sep 18, 2013Explorer
These are the things we bought for the camper:
http://tweetys.com/50-amp-portable-surge-protector-polarity-tester.aspx
http://tweetys.com/electrical-management-system-hardwire-50-AMP.aspx
The surge protector does what it says, after it indicates all is well with the pedestal, then the camper is plugged into in, then it goes thru the transfer switch, and then the EMS. This EMS is supposed to detect, high or low voltalge, and open neutral, and block damages to the camper and things inside. Since this did not indicate a problem, it tells me that whatever is occuring is between the EMS and the everything else. Cause the EMS was not damaged nor was the transfer switch.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
