MEXICOWANDERER
Sep 19, 2013Explorer
Back when I commuted to work by air (Pterodactyl) I got sucked into recovering new RV "burnouts" so they did not have to be totaled. Proofing a circuit takes time and patience, and comebacks and risk of unintended disaster. I had neither time or patience, wanted no comebacks, nor wished to attend funerals.
I LOADED each circuit to the max. Some with 1,650 watt loads, and multiples thereof to proof incoming feeder lines. Voltmeters, a KW meter on the incoming power, and several fire extinguishers. I used a thermography scanning tool to double check receptacle integrity, breakers, switches, converters, etc. Today a simple IR scan tool the likes of a HF would do fine. As would a pair of electric heaters. Two days to check out a 35' motorhome or trailer. GOOD SAM moaned when I gave them the bill. But they paid and then immediately set me up for the next one. "Jeez I only did this the first time because I knew the guy" he was a golf pro and purchased a lot of batteries off the distributor I subcontracted to. They ended up low-boy'ing rig after rig. Then came a PREVOST. I had to beg off. This occurred not all that far from Los Angeles.
I would park the "repaired" rig far enough away from a dwelling so as to not endanger it. Then use heaters, and a voltmeter and an IR scan tool, and take my time, if I were you.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
