CT_WANDERER's avatar
CT_WANDERER
Open Range SlideOut
At a park and neighbors has a Open Range 5Th one of the slide outs got racked on the way out. He asked me if I Could help him. Found out that the one of the Chain/Cable system come off the sprocket and the same side the cable cam off the wall bracket. Plans are to try and reattach it tomorrow. It was late. Not sure of the make, hopping someone can give in some information on what the make could be and anything I need to know about reattaching the chain & Cable. Thanks
  • The weak link with a Norco Accu Slide is usually the OEM installation. The pulleys pull loose from the sidewall due to lack of backing or over tightened/incorrect fasteners.
    Good luck, depending on layout some can be a real bear to get at everything. May have to remove fascia trim.
    Accu Slide Tech Docs
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
