- Artum_SnowbirdExplorerOr, if you can get close enough, use your jumper cables from the Pathfinder and connect to your battery leads.
- BFL13Explorer IIWith batteries in, the slide motor positive wire is connected to the converter's positive wire on the pos battery post, so there is a path from converter to slide motor.
No battery, you have to join those two pos wire ends to complete the path. Vice grip pliers is one way to hold them together. The neg path is ok since each is on the frame. - 2oldmanExplorer IIprobably
Having RV issues? Connect with others who have been in your shoes.24,212 PostsLatest Activity: Mar 12, 2025
