wiregrassw's avatar
wiregrassw
Operating TV while driving down the road.
The TV/DVD doesn't work unless the generator is running in my newly purchased 2005 BT Cruiser. Manual says there is an inverter but don't know if there is a switch to turn it on? Should this be automatic or should I have to turn on a switch?
  • Typically if you have an inverter this is a switch somewhere to turn it on. Also, if the TV is mounted in the dash or in the cabinets over the windshield there is likely a device installed by law that will not let the TV operate when the ignition is on.
  • There should be a switch and not all outlets are usually powered by it.
    And most RVs have a relay that prevents the tv from being on when the engine is running. I have defeated that on all my RVs either by disconnecting the relay or the wire or using another outlet. Ain't nobody's bizness but mine if the TV is on going down the road.
  • I hope the tv dvd is in the back seat and you aren't watch it while driving.
