- The_TexanExplorer
- tkcas01ExplorerTypically if you have an inverter this is a switch somewhere to turn it on. Also, if the TV is mounted in the dash or in the cabinets over the windshield there is likely a device installed by law that will not let the TV operate when the ignition is on.
- Big_KatunaExplorer IIThere should be a switch and not all outlets are usually powered by it.
And most RVs have a relay that prevents the tv from being on when the engine is running. I have defeated that on all my RVs either by disconnecting the relay or the wire or using another outlet. Ain't nobody's bizness but mine if the TV is on going down the road. - old_guyExplorerI hope the tv dvd is in the back seat and you aren't watch it while driving.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
