JimK-NY
Oct 30, 2021Explorer II
bfacklam wrote:
.... Looking at 2,000 to 2,500 watts. Mainly for coffee maker, nebulizer and recharging phones and computers. ....
The first step should be to do an energy audit and reduce consumption if feasible.
There are plenty of great coffee maker options that work with water heated by your propane stove. Get rid of the electric coffee maker and the need to run a generator just to make coffee.
Power consumption for the rest of the items you mentioned should be minimal and can be done directly at 12 volts or with a very small inverter and little consumption of power. That is certainly true for charging cellphones. There are plenty of nebulizers that operate on built in batteries which can also be easily recharged with little power consumption. We have 12v chargers for out Dell laptops and power consumption is low.
You should not need a 2K or larger generator unless you also want to run a a/c unit or microwave. If you do need a larger generator, then I also recommend a Honda.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
