RJsfishin's avatar
RJsfishin
Optima, Gel or AGM, Advertised as both, which is it?
This question came up,.......
Optima, gel or AGM, which is it? Whats the difference? Its advertised as both.
I know what an "absorbed glass mat" battery looks like inside, because I sawed one in half.
  • Chris Bryant wrote:
    Geeze- 2 minutes on the Optima website gives the faq
    "Optima Battery Company" wrote:
    What is a gel battery? Is OPTIMA® a gel battery?
    A gel battery design is typically a modification of the standard lead-acid automotive or marine battery. A gelling agent is added to the electrolyte to reduce movement inside the battery case. Many gel batteries also use one-way valves in place of open vents, which help the normal internal gasses to recombine back into water in the battery, reducing gassing. Generally, gel batteries are less tolerant of high heat and are charged at lower power than traditional or AGM batteries. An OPTIMA battery is neither a gel battery nor regular flooded battery. OPTIMA is a SPIRALCELLTECHNOLOGY AGM battery.
    This here.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    RJsfishin wrote:
    Ok, seems this really is a gell cell. So a gel cell is still a lead acid !
    I wonder what their good for, except emergency standby ?
    Optima is AGM,,, It comes up under a search for GEL for two reaons. One people do not know the difference, Two: AGM's have all but one property of GEL, and that property is a DISadvantage (GEL's are very finikey eaters, if you do not charge them properly... You replace them).
    But yes, GEL cells, like AGM and Maintenance free, is of a battery class called Valve Regulated Sealed Lead Acid.
    All three have some properties in common (You do not have removable caps, you do not add water, they are low-gasing) And in addition GEL and AGM have the added feature of being able to mount in "odd" positions, Upright, on end, on edge, upside down, tilted and more. In addition SOME (Lifeline) AGMs can be recharged very very fast (GEL on the other hand is the slowest rechargeable of all batteries).
    AGM's are much more "Forgiving" of abuse than Gel
    And I believe AGMs are approved for air travel.. Not sure of Gel.
    OPTIMA, in addition to all this.... Has about 60% of the capacity of a same size class any other make or type (For example a G-29 is about (rounded) 100 amp hours, unless it's an optima and then it is about 60.
  • Geeze- 2 minutes on the Optima website gives the faq
  • Ok, seems this really is a gell cell. So a gel cell is still a lead acid !
  • smkettner wrote:
    I don't think you will find "GEL" on the oem website.
    Optima is only AGM.
    Light gray case is deep cycle. Beauty of AGM is that even deep cycle has lots of cranking amps and so it will carry a start rating same as other 12v "true deep cycle" such as Trojan.
    Right, but OPtima sure likes to come up under gel batt search.
    Is this a gel cell, or a sealed lead acid, or AGM ?
    Seems like their all the same now?http://www.batterymart.com/p-12v-74ah-sealed-lead-acid-gel-battery.html now ? Why is this so hard ? Why worry about it ? Cuz I'm in the middle of an argument ! And I don't
    like loose'n !:)
  • I don't think you will find "GEL" on the oem website.
    Optima is only AGM.
  • Optima does not make a true deep cycle battery. I chose a Lifeline AGM because it is demonstrably one of the best in part because of it MIL spec FAA heritage.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Optima is AGM, Sprial Wound AGM, it has roughly 60% of the capacity of the same size class Regular battery (Be it AGM, Maintenance Free, or Flooded wet cell).
    Many people confuse Gel and AGM, because in many respects they are the same
    Both are Valve Regulated Sealed Lead Acid batteries
    Both can be mounted "This side up" or any other way you want to mount them, On edge, On end, Even upside down.. They do not leak and they are low gasing.
    However there is a big difference:
    Where as some AGM batteries can take recharge very very fast, (Lifeline at one point recommended an initial charge of up to 3 times the amp hour rating (20 hour rate) so a Common Group 29 could take 300 amps of charge.. Other makes do not make quite a bold a recommendation0.
    GEL's need to be SERIOUSLY babied,, (Say 25 amps) and where AGM's are a bit forgiving of some abuse things,, GEL is not, not at all. Do not overcharge a Gel ever.
    This is why GEL cells are usually restricted to use in electrnic devices that have a good charge controller, and are also usually only smaller (Single digit amp hour rating) batteries and even there AGM is replacing them.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
