time2roll
Nov 19, 2018Nomad
rhagfo wrote:Odd feature to tell you when both are empty because I want to know when one is empty. That little window was very hard to read with fractions of a millimeter to determine the primary cylinder is empty. As I sad it was hard to hit correctly and I was often short or long in getting the cylinder filled. BTW no regulator indicator is needed when both are empty because at that point I just know.time2roll wrote:I really like our Marshall as it would tell if one or both tanks were empty. It turns half red when the primary tank is empty, and all red if both are empty, or backup is turned off.
That Marshall is what I had and disliked the whole time. Indicator would sort of creep up and was hard to tell if the cylinder was truly empty. Almost ran out a few times second guessing after pulling a cylinder and it was still 30%. The window became very fogged over time making the read even worse.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
