wopachop's avatar
wopachop
Options for propane regulators
I have the mixing valve that automatically switches over. Its leaking and also has a bad hose. Trailer is only 5 years old. My friends tell me the regulators are junk and fail often.
Is there a higher quality brand lots of people install?
Buy cheap and replace every couple years?
Was considering ditching the mixing valve all together. Does a regulator designed for propane BBQ work at the same pressure as an RV?
  • Same pressure? - yes.
    Grills typically use a single stage regulator, you should have a dual stage regulator on an RV.
  • I prefer a non-automatic propane switch valve. When one bottle runs out I switch and refill the empty one. If an “automatic” mode allows you to monitor and adjust, fine. If “automatic” means “no thinking needed,” I say nope.
Having RV issues? Connect with others who have been in your shoes.24,336 PostsLatest Activity: Nov 16, 2025
