wa8yxm
Feb 28, 2017Explorer III
Using both Gas and Electric, at the same time, if possible (not always) improves recovery time
Atwood makes a 10 gallon water heater that fits in a six gallon hat. What it does is over heat the water than mix cold in via an automatic mixing valve so you get 2/3 more hot water... NOTE: the mixing valve is an additional point of failure, but I've not heard bad things about them.
Finally there is a type of water heater called a "Tankless" or "Demand". these run on Propane only.. And ONLY when hot water is requested,, So though they burn a lot of propane when running, they burn ZERO when you are not drawing HOT water.. The result is they use less,, over all.
The other advangage is they can heat 2 Gallons per minute easily to shower temp, You never run out of hot water unless you either Run out of A: water or B: propane.
