MrWizard
Aug 26, 2016Moderator
Must be that some of these little heaters don't have the propane connection but the one in the pic you posted does. The little brass circle inside the hole on the front of the heater base is where it connects. Way cheaper to run on propane than on those little butane cans.
I think That is a screw on butane hose connection, a European standard
They have adapters that go between the two standards
The ultra tiny pocket size cooking burners use a hose to connect to a butane bottle that looks like the bottom of a Coleman lantern
I suppose there is an adapter that goes from that to propane bottle
