hugemoth
Aug 27, 2016Explorer
The heater came with a hose adapter that attaches to the brass fitting at the front of the base. It's made for a 3/8" or 10mm ID hose. Why so large I don't know. Low pressure propane works fine and I suppose butane would as well. I use a regular 20 lb propane bottle with a standard low pressure regulator.
MrWizard wrote:
I think That is a screw on butane hose connection, a European standard
They have adapters that go between the two standards
The ultra tiny pocket size cooking burners use a hose to connect to a butane bottle that looks like the bottom of a Coleman lantern
I suppose there is an adapter that goes from that to propane bottle
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
