hugemoth
Aug 28, 2016Explorer
I'll get a pic of the hose adapter later today.
Looking at some online pics of this heater it appears that some don't have the regulator with the brass inlet for propane, but otherwise they're the same.
I also just bought a dual fuel camp stove similar in design to the heater. It comes with a hose to attach an external 1 lb propane bottle or you can use an internal can of butane just like the heater. The regulator on the stove has a threaded brass piece around the standard butane connection so the propane hose can screw on in place of the butane bottle. The hose has a built in pressure regulator. The propane connector on the heater is separate so both propane and butane can be attached at the same time.
