carl2591
Dec 26, 2017Explorer III
while i do have two panels i as planning on only using one of them and it sounds like that is all the MPPT can handle. and using a 12 v volt system. In reading the article posted it appear I might need a DC to DC convertor to lower voltage?
carl2591 wrote:
I was gifted a couple of 335 watt solar panels the produce 46.3V Voc, 37.9V Vmp, 8.8A Imp, 9.36A Isc.
I have a 20 amp MPPT controller that might work but not sure as the info show 12 or 24 v operation. Is this considered a 24 v system??
This is going on camper shell to provide extra power when needed or if RV parked in shady spot. I was going to mount this spare MPPT and take some wires out to a connector so i can plug in large panel to put power to mppt controller to help charge up 2-6 v batteries. (12V)
there will be several 12v panels of about 360 watts total which could be wire in series to make 24v system but do to shading issues my stay parallel. '
Not sure the best way to go on this system.
I have checked voltage and with full sun it at like 46 volts DC (not hooked up to any thing just the leads)
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
