BFL13
Jan 03, 2018Explorer II
You can put the PWM and the MPPT on the same battery bank and they will add their amps if their set voltages are similar. It is the voltages that count, not whether they are in bulk at the same time. It is no different from any number of chargers on a bank at the same time. Keep their voltages nearly the same.
I don't know what the Bogart's voltages are. The Tracer will go to about 14.6 or 14.8 (you can adjust a little by picking AGM or Flooded)and then stay at that for 2 hours then drop to about 13.6.
So for most of the day they ought to be fairly close in voltage to mostly add their amps if the Bogart high set point is about 14.6 or so.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
