N7GLD wrote:
I live in an off grid home with 2400 watts ( and expanding ) of solar panels with and Outback 80 amp charge controller. I've maxed this controller out
You've maxed it up at 24V battery bank. If you go 48V, you can double your solar wattage without buying another controller.
SMK is right, this controller is not too automated when it comes to absorption.
I wonder if my Rogue 30 is the only MPPT with automatically adjusted Abs time. It terminates Abs stage when current drops to preset (adjustable) value. And, if it doesn't drop, then preset Abs timer (also adjustable) kicks in. In storage it's keeping Abs time very short, some seconds, as the current drops quickly after it hits Abs voltage. I already hear all the flooded crowd screaming - "Heresy! Keep'em jars boiling!" - well, mine are not flooded. I don't think they need much boiling in storage, either.
