I am thinking of installing my Wi-Fi router in a waterproof box behind my camper rather than running coax inside. Will the signal stay strong as it passes through a plastic box and the aluminum trail...
Don't sweat the small stuff. All you need do is look at your available Wi-Fi's in your park while sitting in your rig and you will see that aluminum has little effect on your signal.
Heck all you're doing is the same thing that parks that offer free Wi-Fi are doing.
FWIW, I helped a guy in this park by simply adding a splitter at the post then running the router into his bay area. Works like a charm.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
