I am thinking of installing my Wi-Fi router in a waterproof box behind my camper rather than running coax inside. Will the signal stay strong as it passes through a plastic box and the aluminum trail...
I would keep the router inside for easy wifi connection to it. Run a short, permanent cable to an outside jack for an antenna. It could be permanently mounted on your car port or set on the roof at a campground. I would use a directional antenna to quadruple the signal strength. eBay long range wifi antennae
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
