SCClockDr
Apr 05, 2016Explorer
bgradert wrote:
All-
If you were to hook a TV up to the outside jack and put a movie in the DVD player, would you be able to see the movie on the outside TV?
There are many things to consider.
- The outputs your DVD player has.
- Is your unit equipped with a Wingard MultiSwitch?
- Do you have an HDMI Switch?
- What wires are present.
Our Samsung HT has only HDMI, Component, and composite outputs, so I would need an HDMI cable Multi-switch or component/composite cables from the HT to the outside TV. All 3 of the Wingard switch destinations are spoken for and there is no HDMI support.
Another limitation is the Wingard Multi-Switch supports only 3 destinations, Main, TV2 (usually BR), & TV3/VCR (usually the Home Theater or Receiver/Amp) so splitting the BR coax could get it done.
