We use our oven often. Last trip out The pilot lit fine but burner would not ignite until I blew air through a straw near pilot lite area then all was fine. How does one clean out these little openi...
An old tooth brush. I sometimes have the same problem. I light the pilot light with a long butane bar-b-que lighter and if it doesn't light the burner right away I'll hit the burner with the lighter. The problem I think is it takes a minute for the thermocoupler heat up to open the valve.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 13, 2026
