homefor2's avatar
homefor2
oven door removal
has anyone removed the oven door from a Magic Chef ? I don't want to break anything so need to know the right steps. It does not simply lift off like most domestic oven doors.
  • homefor2 wrote:
    I figured it out. The Magic Chef oven has a bottom hinge and 2 larger levers at the bottom. The larger levers are spring loaded and have a hole in each one.
    1. With the oven door all the way open, grab the larger lever with a pair of channel lock pliers and pull down and towards the door handle. Be careful not to let go as they are spring loaded. Having someone help put a nail in the hole of the lever will make it easier.
    2. Do the same on the other side then you can lift the door till the nails take the pressure of the spring
    3. Undo the small bottom hinge that's held on with a phillips screw. Support the door while removing the screws and it comes off.
    The reason for taking the door off was to facilitate modifying the oven and burners to an electronic ignition as posted here: Electronic ignition
    Exactly what I did and you will be happy with the electronic conversion.
  • I figured it out. The Magic Chef oven has a bottom hinge and 2 larger levers at the bottom. The larger levers are spring loaded and have a hole in each one.
  • On ours Attwood, open door, remove the 4 screws in the door holding the hinge. Then lift up.
  • Thanks but that seems like the domestic type of oven. The RV version is not that simple unfortunately.
    Don't know if this will help. Sounds pretty simple.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
