sstan's avatar
sstan
Oven Won't Stay Lit
I have a Smev range in my truck camper. It uses piezo spark ignition for the burners and oven. I'm having a problem now with the oven staying lit. It lights fine when holding the knob in but goes out as soon as I release it. I just tried installing a new thermocouple but the problem remains.
Any ideas?
Thanks, Steve
    Any ideas?
    Thanks, Steve
    I know this sounds simple, so please know I mean no offense. When you hold the knob in and light it, do you continue to hold it in for a short while....maybe 15-20 seconds??? If you release the knob at the very second it lights, it will almost always go out.
    Just a thought...
    Christian
  • SMEV was bought out by Dometic. I searched the Dometic website, and found the owners manual. Reading through it, you might want to try the manual lighting method to see if it will work.
  • If the thermocouple reads 13mv or higher it should be good.
    Using a meter set on mv you put one lead on the end and one on the side.
    This reading has to be done when the thermocouple is in a flame.
  • Can it be tested? Throwing parts at it is a little inconvenient. The stove is made in Sweden and Dometic has recently purchased this brand but so far is not importing parts. I had to go to the UK for a thermocouple...
  • That is the condition of a bad thermocouple.
    It is not unheard of to have a new one that does not work as well
