Blutoyz
Oct 03, 2017Explorer
rk911 wrote:Blutoyz wrote:
Hey All,
As I dig in to this new hobby I see that there is more to do. I have a winegard sat antenna that came with the rig but no sat boxes so I won't be doing satellite. I just want some over the air options to wire up the 2 new LCDs that are in there.
I have the original antenna on top and a coax near there (was up there for the sat) that I can connect. So I can hit you with 2 questions right now:
1. How do you find the batwing antennas for reception?
2. I don't seem to have an inverter so will have to add one. What are your thoughts about an TV/xbox and a couple of lights on a 2 batt house bank?
the batwing should have a short piece of coax running from the head (where the wings attach) to a connector on the roof. do you see that?
somewhere in the RV you should find a wall plate, usually near the crank up handle. on that plate you should see a small button. push it and an LED on the panel should glow. that plate energizes the amplifier in the batwing head.
do you have a media switch box allowing you to switch the antenna, satellite, DVD players, etc. into either TV? if so be sure that TV or ANTENNA (ANT) is selected for each TV
using the owners manual for your TV scan for channels. you may have to rotate the antenna 90-degrees and scan a second time since the batwing is a directional antenna.
let us know what your results are.
Thanks for the info...I will post after I mess around with everything this weekend
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 20, 2026
