DrewE
Oct 03, 2017Explorer III
As BFL said, there's no problem running the TV on an inverter. An Xbox uses a bit more power than a modern TV (around a couple hundred watts or so, I think), so you shouldn't get too small of an inverter, but 500W or 600W should be entirely sufficient and that could run fine from a pair of batteries if wired up decently well.
The lights in your camper are 12V and would not be running on the inverter.
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 20, 2026
