wa8yxm
Oct 04, 2017Explorer III
The Batwing depending on the model and station is the best made As follows
VHF any batwing
UHF Any Batwing WITH WINGMAN (On the Sensar II and III that is an add on)
You should have a coax to the roof for that antenna,,, may be at the base of where the original antenna was or may have been re-tasked.
The system
Antenna coax to roof line, junction there to a box inside the RV, now in most RV's this is a wall plate with a 12 volt outlet, antenna connection, Switch and light.. THIS IS THE ANTENNA POWER SUPPLY.. Replace it with a Sensar Pro module (About 100 dollars if DIY).
My RV has a "Box of many buttons" (Matrix switch) so I added the SENSAR PRO
Antenna---Roof top connector----Sensar Pro---(Optional bomb)----TVs
Get one of the TV finder apps for yoru smart phoen TV-Antenna Helper Free is the one I use.
My only problem... TOO MUCH TV, can't watch it all
VHF any batwing
The system
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 20, 2026
