maillemaker
Jun 03, 2018Explorer
Call me silly, but you *DID* check that you don’t just have a bad thermostat or seized clutch fine ...... right?
Either one of those will cause exactly the symptoms you describe and not respond to any magic flush potion.
I actually bought a thermostat, as I thought that was the problem. It was when I was draining the coolant to do that that I noticed the sediment in the radiator. So I did not replace the thermostat.
I'm a bit concerned because the Chilton manual says the thermostat should have some kind of sleeve gasket which I don't even see how that would fit on a thermostat since it looks like a flying saucer not a cylinder.
Maybe I'll order a Motorcraft thermostat instead of the one I got from O'Reilly.
I did not check the fan clutch.
Steve
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
