dougrainer
Mar 06, 2023Nomad
joebedford wrote:
There were no fault codes.
I didn't monitor the voltage because it seemed to be fine until it wasn't.
I'll check the voltage next time I run it under load.
When you say "kill" do you mean make it stop or break it?
Bad choice of words. Yes, it may stop running if too much oil. It can cause the LOPKO(oil pressure switch) to not see the pressure. Doug
