StirCrazy
Aug 23, 2019Moderator
wow, cant believe how many people are telling you to do somthing else when you already have a fantastic setup, you can disinfect every fill up, no chemicles or after taste at all. do you have more info on your set up? ie. what is the output of the generator etc? the only down side to O3 is that it might be hard on some of the plastices in the rv plumbing, if one were to replace the fixtures with metal ones then this would be come a non issue, or if you let it sit in your tank for a few hours then the o3 should be dissapated by the time you use it.
Steve
Steve
