TechWriter
Aug 24, 2019Explorer
steved28 wrote:
I now use a venturi when filling my tank which injects ozone from a small ozone generator. No more smell, and the O3 removes more nasties than chlorine.
You are using this guy, right? The AZ2 manual is pretty straight forward and says you can treat up to a 500 gallon spa. Pretty impressive for under $100.
However, treating with ozone depends on water pH and dwell time. Ozone levels should be adjusted for different water pH levels and how long the the ozone contacts the water. I'm guessing the AZ2 isn't sophisticated enough to do all that.
Also, make sure to remove all filter cartridges ahead of your AZ2 as ozone will destroy these. Finally, since ozone is such a strong oxidizer is also can destroy natural rubber, some plastics, and synthetic rubber -- like gaskets.
Finally, your water may smell better, but there's a good chance the water isn't actually being disinfected and probably not your water tank and system either.
I suggest a UV system instead. None of the ozone side effects and UV does essentially the same thing as ozone.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
