steved28
Aug 26, 2019Explorer
StirCrazy wrote:
wow, cant believe how many people are telling you to do somthing else when you already have a fantastic setup, you can disinfect every fill up, no chemicles or after taste at all. do you have more info on your set up? ie. what is the output of the generator etc? the only down side to O3 is that it might be hard on some of the plastices in the rv plumbing, if one were to replace the fixtures with metal ones then this would be come a non issue, or if you let it sit in your tank for a few hours then the o3 should be dissapated by the time you use it.
Steve
Thanks, I thought the same. This is the unit I use. Although there are many on the market. And this is the venturi. ANd yes, I just let the ozonated water sit in the tank. Unless I want to get some into the hot water tank, then I pump it through the HW system immediately.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
