smkettner wrote:
Four GC2 and you charge every morning? You are probably just using the top of the battery where charging is slower and less efficient. Is the battery down close to 12.2 volts ever?
And if you are in the sun much... 100w or 200w of solar might eliminate the generator in most conditions.
/\ This. Or run the generator with the PD 9245 in boost mode (solid) on the pendant, for an hour, first thing in the morning, put 45 amps in, and let a 120 to 160 watt solar panel top it off the rest of the way the rest of the day.
