MFL
Apr 24, 2018Nomad II
I use a bearing packer, after cleaning/inspecting bearings. It does waste a little grease between the two cones that the bearing is in. I buy grease by the case from wholesaler, so not a big deal. My packer has a zerk to fill/pack, and when done, the bearings are solid packed. It is always best to keep bearings matched to the races they have been running in. I am not afraid to use the EZ-lubes and see no need to repack every year, unless an issue arises, that requires pulling the hub.
Jerry
Jerry
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 19, 2026
