SCVJeff
Oct 24, 2014Explorer
NinerBikes wrote:Does your fancy supply have enough range to bench test that?mena661 wrote:
Very nice Niner, we can put that TV on the low power "list".
Hard to tell for sure, but it's a far cry from the 40 watts from the last unit. I am sure that the heat from the brick and the heat from the inverter, if I cut out the conversion from 12V to 120V then back to 14 or 12, what ever the out put of the brick... pretty sure I can do better with less load on the battery if I do a 12V direct battery to the TV and bypass the brick/converter.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
