BFL13
Jun 16, 2014Explorer II
JiminDenver wrote:
So a simple test if one of us gets the time to prove that the extra amps from the buck converter are always available even in float.
Have the 230w panel set up with the battery in float. Put a load on the system and slowly increase it but not so fast or high that it brings the batteries voltage below float and takes the charger into MPPT mode.
If the theory is correct, 230w/13.6v = 16.9a not accounting for loses and inefficiency. With the right load you could see 16a in float. I know I've seen over 13a in float and over 16a in bulk. If you can tweak the load to that point with out kicking the controller into bulk, it means that MPPT doesn't create extra amps at all, the converter does. MPPT just controls what volts and amps are needed to best charge the battery the fastest.
On low voltage systems there is still enough excess voltage to see some conversion at the converter and the program can then decide how to best use it in bulk.
Not too sure this is what you wanted but:
Trimetric says 14.3v, 4.1a (which is pretty much all to the battery) and we are down minus 7.39AH (so nearly full out of 458)
Eco-W readout says: Float, 14.4v, 5.22a, 75W (out of 230w panel)
Demo says PWM is 8.02a (Panel Isc rated 8.3a) Time is 4PM with sun lower than at noon of course, explaining why Isc is less than rated, panel in contraption more or less aimed. Demo MPPT is 12.75a (but we are in Float) at 59% efficient.
Turned on some loads:
Trimetric says 14.3v, 4.0a, -7.26AH (Tri only shows battery amps)
Eco-W says Float, 14.4v, 11.3a, 161w
Demo says PWM 8.07a, 12.95a MPPT (but amps are 11.3 in Float)
So the solar is picking up the load with the extra amps, well above panel Isc rating, and the batts are still getting the same 4a as without the load. (So load was about 7.3a.)
