mlts22's avatar
mlts22
Explorer II
Jun 06, 2016
Panel setup for a camp for three months?
Come the beginning of the year, I make a camp where I hit on weekends for a renaissance festival. This lasts until April.
I've been thinking of solar panels, but it would be a semi-permanent affair where I'd have a weekend or two to build it, and a weekend to tear it down, so it can be bigger than a 100 watt panel on a rig.
One thing I've seen someone do was to use three 20 foot long flexible solar panels, staked out, attached in series to a MPPT converter.
The biggest issue are winds. They can gust up to 50+ mph, so just a lean-to with panels isn't a good idea.
Any suggestions on this? It would be nice to get about 500+ watts, as that can definitely charge a battery bank during the weekday, while I'm gone.
  • Almot's avatar
    Almot
    Explorer III
    I couldn't figure out how to lift that 250W monster on the roof with just a ladder. Thought of lifting it on the ropes and pulleys, but then decided to call neighbors at the camp. They didn't mind, snowbirds have nothing else to do.
    Yes, people normally install more than 100W on RV roofs. Some of them are tilted, and can be build similarly on the ground. In fact, much easier, - on the ground you just stake it down with pegs or anchors. No messing with tapping screws and sealant. With so many solar farms in rural areas there should be commercial racking solutions too.
  • Do you mean a temporary structure on the grounds of the Renaissance Fair for week end use,
    You can't spend the weekend in your RV ?
  • Almot's avatar
    Almot
    Explorer III
    Flexible panels are not an easy material to build anything. Go rigid.
    I don't see a problem building a rack of 1/8" or 3/16" aluminum angle, with vertical arms on the North side and horizontal struts connecting the bottom of the arms with the front of the panel. Assembled on screws or pins, and panels fastened with the same. Horizontal struts would be staked to the ground. Shouldn't take more than a few hours to assemble every time.
    Theft possibility? With prices of big panels approaching prices of 4x8 plywood - not very likely to find somebody THAT desperate. Use rivet-nuts and tamper-resistant screws if you're worried about this. McMaster have some very tricky screws that fit only their proprietary screwdriver.
    I've seen this kind of rack on a top of a van, was made of rusty steel slotted angle and cheap fasteners. The whole contraption was attached to his roofrack as I recall.
    Westend here has made something along these lines (of aluminum and stainless hardware) on top of his trailer, ask him about photos.
    Of course, if you will have the whole weekend to build it every time, you can build it from 2x4 from a local store.
    I hope you realize that each 250W panel weighs 42 lbs and requires 3 people to lift it to any roof over 6ft height - 2 people lifting and one grabbing it from the top.
  • Buy a used two wheel trailer and build the solar system on that, then you can always lock it to a MH or a camper.Plus when you are there you can move it around to get the most sun.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
