BFL13
Apr 15, 2017Explorer II
CA Traveler wrote:BFL13 wrote:The MPPT60 is limited to 60A. There is no stated input/panel watt limit.
If at 14.8v battery and the output watts limit is 800w can you ever see 60 amps? I think it would be limited to 800/14.8 = 54 amps but I don't own one to have noticed that.
It's clearly stated that if the panel watts should result in exceeding 60A output the CC will derate to 60A.
OK I see now what MS does as explained here in Q1--they use 13.33 battv
http://support.morningstarcorp.com/wp-content/uploads/2014/07/MPPT-Technology-Primer.pdf
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
