Salvo
Apr 14, 2015Explorer
The efficiency difference between 30V and 90V is wattage dependent. In cloudy conditions or when sun is low the difference is 5%. The difference decreases to 2% at max wattage.
70 feet of 4 gauge cable (17.36 mohm) will drop voltage 1.4% when conducting 3 x Imp or 24A. Given the inefficiency of the controller, this setup will produce more current than a series configuration. Under low light conditions, the difference will be close to 5%.
What about wire cost? Home Depot sells stranded #4 for $1.19/ft. #10 goes for $0.66/ft. The difference is $37.
2oldman wrote:
That could be a wash, considering any inefficiency of a higher PV voltage at the controller.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
