Salvo
Apr 15, 2015Explorer
Serial will produce more as long as the bypass diodes conduct. If the diodes do not conduct then series is significantly worse off.
It all depends on the type of shade. If the shade is produced by an object close to the panel then the diode will conduct. On the other hand if shade is produced by a tree farther away, covering an entire panel the diodes may not conduct. Series will have a significant decrease in power. You can test this scenario by tilting one panel 45 degrees away from the sun.
CA Traveler wrote:
There is not always a simple black and white comparison of serial vs parallel panels and shade. Serial panels with bypass diodes can significantly outperform parallel panels with shaded panels.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
